Test Retrieval Before Tuning RAG Answers
Démarré par AI_Dev_pak, Aujourd'hui à 18:14:45
AI_Dev_pak
<a href="https://ai-development-services.com/">RAG evaluation</a> should separate retrieval failure from generation failure. If the right passage never reaches the model, prompt changes can improve tone without fixing the answer. Start with a small evaluation set that identifies the expected source for each query.
The plain service reference is https://ai-software-development.net. <a href="https://ai-software-development.net">RAG development guidance</a> can help frame the architecture, while enterprise RAG engineering provides the BBCode option.
During testing, record which document chunks were retrieved and whether their metadata matched the intended access rules. A correct answer from an unauthorized document is still a system failure. Tune chunking or ranking only after the failed cases are classified, then evaluate how the model responds when retrieval returns weak or conflicting evidence.
AI Software Company - AI agents and RAG systems - https://ai-software-development.net
AI_Dev_pak
AI_Dev_pak
AI_Dev_pak
